SHORTCUTMENU system variable
Shortcut menus
Controls the status of the DEFAULT, EDIT and COMMAND (right-click) context menus.
Type:
Short
Saved in:
Registry
Range:
0 to 63
Default value:
3
Possible options:
0: Disable all Default, Edit, and Command mode shortcut menus
1: Enable Default mode shortcut menus
2: Enable Edit mode shortcut menus
4: Enable Command mode shortcut menus (available whenever a command is active)
8: Enable Command mode shortcut menus only when command options are currently available from the Command line
16: Enable a shortcut menu when the right mouse is held down
32: Repeat command with short right click when entities are selected and Quad is not shown
