SHOWIDSPROPERTIESONLY system variable
Show IDS Properties Only
When an IDS-XML file has been imported, this setting controls whether only the properties required by the IDS should be shown in the Properties panel, or all properties should be shown.
BricsCAD only
| Type: |
Short |
| Saved in: |
Drawing |
| Default value: |
Off |
| Possible values: |
Off (0): Show all properties On (1): Show only the properties required by the IDS |
