SHOWLAYERUSAGE system variable
Layer Usage
Shows information about layer usage in the Layers panel.
In the column Current, the Layer Usage icons indicate when viewport settings for the current layout and paper space viewport are different from model space settings:
| Type: | Boolean |
| Saved in: | Registry |
| Default value: | Off |
| Possible values: |
Off (0): Do not display Layer Usage On (1): Display Layer Usage |
