SINGLETONMODE system variable
Singleton mode
Switch to control whether one or more instances of BricsCAD® can run simultaneously.
- When set to Off, you can launch two or more copies of BricsCAD® at the same time.
- When set to On, only a single instance of BricsCAD® runs if the profile name and current workspace name are the same, and the background instance is responsive, with no command or modal dialog active.
BricsCAD only
| Type: | Boolean |
| Saved in: | Preference |
| Default value: | Off |
| Possible values: |
Off (0): Singleton mode off On (1): Singleton mode on |
