SINGLETONMODE system variable
Singleton mode
Switch to control whether one or more instances of BricsCAD can run simultaneously.
- When set to Off, you can launch two or more copies of BricsCAD at the same time.
- When set to On, only a single instance of BricsCAD runs if the profile name and current workspace name are the same, and the background instance is responsive, with no command or modal dialog active.
BricsCAD only
| Type: | Boolean |
| Saved in: | Preference |
| Default value: | Off |
| Possible values: |
Off (0): Singleton mode off On (1): Singleton mode on |
