SKETCHINC system variable
Sketch increment
The length of segments created with the SKETCH command, in drawings units.
Type:
Real
Saved in:
Drawing
Default value:
0.1
Note: The default value applies when the MEASUREMENT system variable is set to 0 and the INSUNITS system variable is set to inches. When the MEASUREMENT system variable is set to 1 and the INSUNITS system variable is set to millimeters, the default value is 1.0.
