SLICETHICKNESSSTEP system variable
Section plane slice thickness step
Step size used for increments of the section plane slice thickness property.
When set to a negative value, BricsCAD determines the step size automatically based on the section plane properties.
BricsCAD only
Type:
Real
Saved in:
Preference
Default value: -1
