SMASSEMBLYEXPORTSOLIDTYPESINREPORTS system variable
Solid types in reports
Controls the types of solids present in command reports for the SMASSEMBLYEXPORT command. Sheet metal and poor sheet metal solids are always present in reports.
BricsCAD only
| Type: |
Short |
| Saved in: |
Drawing |
| Range: |
0 to 15 |
| Default value: |
1 |
| Possible options: |
1: Non sheet metal solids 2: Standard part component solids 4: Recognize hollow linear extruded solids and treat them as non-sheet metal 8: Recognize circular tube linear extruded solids and treat them as non-sheet metal |
