SMBENDLINESDOWNLAYERLINEWEIGHT system variable
Lineweight of the bend down layer
Controls the lineweight of the 'Bends Down' layer, created by the SMUNFOLD and SMEXPORT2D commands.
Values between -3 and 211 are accepted.
- -1=ByLayer
- -2=ByBlock
- -3=Default
BricsCAD only
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
-3 to 211 |
| Default value: |
-3 |
