SMCONTOURSLAYERCOLOR system variable
Color of the contour layer
Controls the color of the '2D dxf layer', contains unfolded geometry created by the SMUNFOLD and SMEXPORT2D commands.
BricsCAD only
Type:
Short
Saved in:
Registry
Range:
1 to 255
Default value:
7
Related commands
  • SMEXPORT2D command
  • SMUNFOLD command
Related information
  • Working with layers
