SMCONTOURSLAYERLINETYPE system variable
Linetype of the contour layer
Controls the linetype of the 'Contour' layer, created by the SMUNFOLD and SMEXPORT2D commands.
BricsCAD only
Type:
String
Saved in:
Registry
Default value:
CONTINUOUS
Related commands
  • SMEXPORT2D command
  • SMUNFOLD command
Related information
  • Working with layers
