SMCONVERTWRONGFEATURETHICKNESSDEVIATIONTYPE system variable
Type of deviation of wrong feature thickness
Controls if the deviation value is treated as ratio to model thickness or an absolute value. See the SMCONVERTWRONGFEATURETHICKNESSDEVIATIONVALUE command.
BricsCAD only
| Type: | Short |
| Saved in: | Drawing |
| Default value: | 0 |
| Possible values: | 0: Thickness ratio 1: Absolute value |
