SMDEFAULTBENDLINEEXTENTTYPE system variable
Bend line extent type
Controls if the SMDEFAULTBENDLINEEXTENTVALUE system variable is a ratio to the thickness or an absolute value.
The value will be used to initialize sheet metal settings in the document.
BricsCAD only
| Type: |
Short |
| Saved in: |
Drawing |
| Default value: |
0 |
| Possible options: |
1: Thickness ratio 2: Absolute value |
