SMDEFAULTBENDLINEEXTENTVALUE system variable
Bend line extent value
Controls sheet metal bend lines.
Values between -1,000,000 and 1,000,000.0 are accepted.
- Positive value = Stretches past a contour
- Negative value = Does not reach it
- Zero = Just touches
BricsCAD only
| Type: |
Real |
| Saved in: |
Drawing |
| Range: |
-1000000 to 1000000 |
| Default value: |
0.25 |
