SMDEFAULTBENDRADIUSTYPE system variable
Bend radius type
Controls the default sheet metal bend radius.
Absolute value toggles the Thickness ratio. Override bend radius in SMCONVERT controls if the bend radius is taken from SMDEFAULTBENDRADIUSVALUE or from the model.
BricsCAD only
| Type: |
Short |
| Saved in: |
Drawing |
| Range: |
0 to 3 |
| Default value: |
2 |
| Possible options: |
1: Absolute value 2: Override bend radius in SMCONVERT |
