SMDEFAULTKFACTOR system variable
K-Factor value
Sets the location ratio of the neutral surface (the surface not stretched or squeezed when the sheet is bent) to the material thickness.
Values between 0.00000 (internal bend radius) and 1.00000 (external bend radius) are accepted.
BricsCAD only
| Type: |
Real |
| Saved in: |
Drawing |
| Range: |
0 to 1 |
| Default value: |
0.27324 |
