SMDEFAULTRIBPROFILERADIUSTYPE system variable
Bead profile radius type
Controls if the SMDEFAULTRIBPROFILERADIUSVALUE system variable is a ratio to the thickness or an absolute value.
BricsCAD only
| Type: | Short |
| Saved in: | Drawing |
| Default value: | 0 |
| Possible values: | 0: Thickness ratio 1: Absolute value |
