SMEXPORTOSMAPPROXIMATIONACCURACY system variable
Accuracy of the approximation
Controls absolute deviation between the smooth edge geometry of 3D part and its .osm representation with lines and arcs, during the SMEXPORTOSM command, in drawing units. The lower the value, the better the precision.
BricsCAD only
| Type: |
Real |
| Saved in: |
Drawing |
| Default value: |
0.01 - If MEASUREMENT=1 and INSUNITS=4 0.000393701 - If MEASUREMENT=0 and INSUNITS=1 |
