SMOOTHMESHCONVERT system variable
Mesh conversion mode
Controls the conversion mode of meshes to 3D solids or surfaces, with the CONVTOSOLID or CONVTOSURFACE commands.
Type:
Short
Saved in:
Not saved
Range:
1 to 3
Default value:
2
Possible values:
1: Conversion result is smooth and not optimized
2: Conversion result is faceted and optimized
3: Conversion result is faceted and not optimized
