SMPARAMETRIZEHOLESPARAMETRIZATION system variable
Hole parametrization
Controls how straight holes are converted, during the SMPARAMETRIZE command.
If Convert holes to array is on, holes on flanges are converted into parametric, rectangular arrays. If Parametrize holes is on, holes, not already included in arrays, are constrained.
BricsCAD only
| Type: | Short |
| Saved in: | Drawing |
| 0 to 3 | |
| Default value: | 3 |
| Possible values: | 0: Does not parametrize holes 1: Parametrize holes 2: Convert holes to array |
