SMSPLITCONVERTBENDTOJUNCTION system variable
Convert bend to junction
Controls how a split that passes through a bend is solved with the SMSPLIT command.
If on, the shortest side of the bend is automatically converted to a junction. If off, a split through a bend will retain the bend geometry on both sides of the split.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Drawing |
| Default value: |
On |
