SMSPLITORTHOGONALBENDSPLIT system variable
Orthogonal bend split
Controls how a split that touches a bend is solved with the SMSPLIT command.
If on, the split direction for a bend is orthogonal to the bend axis (changes to a 90° angle as it passes through the bend). If off, the split direction is tangential to the split curve (does not change direction as it passes through the bend).
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Drawing |
| Default value: |
Off |
