SNAPISOPAIR system variable
Snap isometric pair
Controls the current viewport's isometric plane (left, top or right), if the SNAPSTYL system variable is set to isometric.
Press F5 function key to set the appropriate drawing plane: Left, Top or Right.
| Type: | Short |
| Saved in: | Drawing |
| Range: |
0 to 2 |
| Default value: |
0 |
| Possible values: |
0: Left 1: Top 2: Right |
