SPAMINUGRIDLINES system variable
Minimum number of U grid lines
Controls the minimum number of U grid lines - the minimum number of grid lines generated in the U direction. Ignored if the FACETRES system variable is in use.
Note: Spa is short for Spatial, the maker of ACIS.
BricsCAD only
Type:
Long
Saved in:
Preference
Default value:
0
