SPAUSEFACETRES system variable
Use FACETRES system variable
Use the FACETRES system variable in place of normal tolerances.
Note: Spa is short for Spatial, the maker of ACIS.
BricsCAD only
Type:
Boolean
Saved in:
Preference
Default value:
On
Possible values:
Off (0)
On (1)
Note:
  • If On, the configuration relies on the FACETRES system variable. Other ACIS modeler settings are ignored.
  • If Off, the configuration allows other ACIS modeler settings to override the FACETRES system variable.
