SPLINESEGS system variable
Spline segments
Controls how many line segments are generated when a spline is converted to a polyline with the PEDIT command.
Values between -32768 and 32767 are accepted.
For negative values, a fit-type curve is applied, composed of arc-segments, yields a smoother curve, but it takes longer to generate.
| Type: | Short |
| Saved in: | Drawing |
| Range: |
-32768 to 32767 |
| Default value: |
8 |
