SPLKNOTS system variable
Spline Knot Parameterization
Indicates the default knot parameterization for splines created using fit points.
Defaults to 0 (chord) on application start.
| Type: |
Short |
| Saved in: |
Not saved |
| Range: |
0 to 2 |
| Default value: |
0 |
| Possible options: |
0: Chord distance parameterization 1: Square-root of chord distance parameterization 2: Uniform distance parameterization |
