SPLMETHOD system variable
Spline Method
Indicates the default method for spline creation (fit points/control vertices).
Defaults to 0 (fit points) on application start.
| Type: |
Short |
| Saved in: |
Not saved |
| Default value: |
0 |
| Possible options: |
0: Create splines using fit points 1: Create splines using control vertices |
