SSFOUND system variable
Sheet Set found (Read Only)
Displays the sheet set file name and path that is associated with the current drawing file.
Type: | String |
Saved in: | Not saved |
Type: | String |
SSFOUND system variable - BricsCAD Lite & Pro | Bricsys Help Center
