SSLOCATE system variable
Sheet Set locate
Opens any associated sheets sets when a drawing is opened.
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: |
On |
| Possible values: |
Off (0): Don’t open a drawing's Sheet Set with the drawing On (1): Open a drawing's Sheet Set with the drawing |
