SSMAUTOOPEN system variable
Sheet Set manager auto open
Opens Sheet Set panel automatically when a drawing is opened that is associated with a Sheet Set. The SSMAUTOOPEN and SSLOCATE system variables must both be switched on to display the Sheet Set automatically.
Type:
Boolean
Saved in:
Workspace
Default value:
On
Note: The default value is Off for BIM workspace.
Possible values:
Off (0): Don’t open Sheet Set panel automatically
On (1): Open Sheet Set panel automatically
