SSMAUTOOPEN system variable
Sheet Set manager auto open
Opens Sheet Set panel automatically when a drawing is opened that is associated with a Sheet Set. The SSMAUTOOPEN and SSLOCATE system variables must both be switched on to display the Sheet Set automatically.
| Type: | Boolean |
| Saved in: | Workspace |
| Default value: | On |
| Possible values: |
Off (0): Don’t open Sheet Set panel automatically On (1): Open Sheet Set panel automatically |
