STANDARDSOPTIONS system variable
Standards validation options
Options to control the procedure of checking standards. The value is stored as a bitcode using the sum of the values of all selected options.
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
0 to 3 |
| Default value: | 0 |
| Possible options: |
1: Fix non-standard object properties automatically 2: Show ignored problems |
