STEPSIZE system variable
Step size
Controls the size of each step, in drawing units, when in walk or fly mode.
| Type: | Real |
| Saved in: | Drawing |
| Range: |
1e-6 to 1e+6 |
| Default value: |
2.0 Note: The default value applies when the MEASUREMENT system variable is set to 0 and the INSUNITS system variable is set to inches. When the MEASUREMENT system variable is set to 1 and the INSUNITS system variable is set to millimeters, the default value is 50.0.
