STRUCTURETREECONFIG system variable
Structure Tree Configuration
Name of the active Structure Tree Configuration file. Use the SRCHPATH command to find the file.
Loading a different CST file than the default file changes the way the Structure panel presents the drawing data.
BricsCAD only
| Type: |
String |
| Saved in: |
Workspace |
| Default value: |
default.cst |
