STRUCTURETREECONFIG system variable
Structure Tree Configuration
Displays the name of the active Structure Tree Configuration file. Type SRCHPATH in the Command line to find the file.
Loading a different CST file than the default file changes the way that the STRUCTUREPANEL command presents drawing data.
BricsCAD only
| Type: | String |
| Saved in: | Workspace |
| Default value: |
default.cst |
