STRUCTURETREECONFIG system variable
Structure Tree Configuration
Displays the name of the active Structure Tree Configuration file used by the Structure panel. Type SRCHPATH in the Command line to find the file.
Loading a different CST file than the default file changes the way that the STRUCTUREPANEL command presents drawing data.
BricsCAD only
| Type: | String |
| Saved in: | Workspace |
| Default value: |
default.cst |
