SURFTAB1 system variable
Surface tabulation 1
Specifies the number of tabulations to be created for RULESURF and TABSURF. Also defines the mesh density in the M direction for REVSURF and EDGESURF.
When extruding entities with arc segments: the SURFTAB1 system variable divides them in a number of equal length intervals.
When revolving entities: the SURFTAB1 variable controls the number of segments of the revolution surface.
| Type: | Short |
| Saved in: | Drawing |
| Default value: |
6 |
