SURFTYPE system variable
Surface-fitting type
Controls the surface-fitting type used with the Desmooth option of the PEDIT command.
| Type: | Short |
| Saved in: | Drawing |
| Range: |
5 to 8 |
| Default value: |
6 |
| Possible options: |
5: Quadratic B-spline surface 6: Cubic B-spline surface 8: Bezier surface |
