SVGBLENDEDGRADIENTS system variable
SVG Blended Gradients
Toggles the use of blended gradients for complex gradient fills for SVG export.
The use of complex gradient fills makes the file size larger.
BricsCAD only
| Type: | Short |
| Saved in: | Preference |
| Default value: |
0 |
| Possible options: |
0: Yes 1: No |
