SVGIMAGEBASE system variable
SVG Image base path
The image file path for SVG export.
If not set, absolute file paths are written to the SVG.
BricsCAD only
Type: |
String Standard |
Saved in: | Preference |
BricsCAD only
Type: |
String Standard |
SVGIMAGEBASE system variable - BricsCAD Lite & Pro | Bricsys Help Center
