TEMPLATEPATH system variable
Template path
Specifies the file path used for the Templates folder.
BricsCAD only
| Type: |
String Standard |
| Default value: |
On Windows: %AppData%\Bricsys\BricsCAD\V27x64\en_US\Templates\ |
| Saved in: |
Preference |
BricsCAD only
| Type: |
String Standard |
| Default value: |
| Saved in: |
Preference |
