TEXTEVAL system variable
Text evaluation
Controls the interpretation of Command line text strings.
When the TEXTEVAL system variable is set to 1, this command evaluates LISP expressions:
Text: (* pi 2)
The result of the equation (pi x 2) is placed as text: 6.283185
| Type: | Short |
| Saved in: | Not saved |
| Range: |
0 to 1 |
| Default value: |
0 |
| Possible values: |
0: All responses to prompts for text strings and attribute values are taken literally 1: Text starting with '(' or '!' is evaluated as an LISP expression, as for non-textual input |
