TEXTSIZE system variable
Text size
The default height for new text entities, has no effect if the current text style has a fixed height.
| Type: | Real |
| Saved in: | Drawing |
| Default value: |
0.2 Note: The default value applies when the MEASUREMENT system variable is set to 0 and the INSUNITS system variable is set to inches. When the MEASUREMENT system variable is set to 1 and the INSUNITS system variable is set to millimeters, the default value is 2.5.
