TRACEWID system variable
Trace width
Controls the default width for new traces, for the TRACE command.
Type:
Real
Saved in:
Drawing
Default value:
0.05
Note: The default value applies when the MEASUREMENT system variable is set to 0 and the INSUNITS system variable is set to inches. When the MEASUREMENT system variable is set to 1 and the INSUNITS system variable is set to millimeters, the default value is 1.0.
