TSPACETYPE system variable
Text space type
Controls the type of line spacing used for multiline text.
- At least: adjusts line spacing based on the tallest character(s) in a line
 - Exactly: uses the specified line spacing, regardless of individual character sizes
Note: The mtexts created with the MLEADER command are also influenced by this system variable's value.
| Type: |
 Short  |
| Saved in: |
 Registry  |
| Range: |
 1 to 2  |
| Default value: |
 1  |
| Possible values: |
 1: At least 2: Exactly  |
