UCSDETECT system variable
UCS detect
Specifies the dynamic UCS. The dynamic UCS is a temporary UCS that is automatically activated when the cursor hovers over a 3D solid's face or 2D entity. A negative value is the same as 0, but helps in storing the earlier value. The value is stored as a bitcode using the sum of the values of all selected options.
Type: | Short |
Saved in: | Registry |
Range: |
-3 to 3 |
Default value: |
1 |
Possible options: |
negative: Disable dynamic UCS 1: Enable for faces of 3D solid and regions. 2: Enable for 2D entities |
