UCSFOLLOW system variable
UCS follow
Controls if a plan view (a top view zoomed to extents) is generated automatically whenever the UCS changes.
If on, turn off the UCSDETECT system variable.
| Type: | Boolean |
| Saved in: | Drawing |
| Default value: | Off |
| Possible values: |
Off (0): Don’t show plan view when UCS is changed On (1): Show plan view when UCS is changed |
