UCSORTHO system variable
UCS orthographic
Sets the UCS to follow the current view, automatically switches the drawing plane to match the current view plane.
Only works if an orthographic view is selected with the -VIEW command or the LookFrom widget.
Does not work if the NAVVCUBEORIENT system variable is set to UCS.
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: |
Off |
| Possible values: |
Off (0): When an orthographic view is selected, don’t automatically activate the related orthographic UCS On (1): When an orthographic view is selected, automatically activate the related orthographic UCS |
