UNITESURFACES system variable
Unite adjacent surfaces.
Unites extruded/revolved surfaces that touch.
The UNITESURFACES system variable is one of the four system variables found under the Extrude mode group.
BricsCAD only
Type:
Boolean
Saved in:
Workspace
Default value:
0
Note: The default value is 1 for the BIM and Mechanical workspaces.
Possible values:
Off (0): Unite adjacent surfaces
On (1): Do not unite adjacent surfaces
